H1,
Since the BeoMaster 5 doesn't have an auxiliary input like the rest of the audio masters, getting sound from a TV onto the system is going to be interesting:
Set up the BeoSound 5 in OPTION 0 (your dealer can help you with this, but it means changing a setting in the menu that tells the system to ignore remote commands) and connect an Active Kit via MasterLink cable. The Active Kit will be in OPTION 6 and this is good, meaning it will accept all types of remote commands. Connect a stereo adaptor to the PC input and connect the speakers to the Active Kit (NOT the BeoMaster 5), then place the Active Kit's eye in a convenient place and you're set.
Pressing N.MUSIC or N.RADIO will engage the sources on the BeoSound 5, while PC will turn to the local input on the Active Kit. If you don't see the active kit, you'd hardly know there was anything funny going on.
There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
