        1st March February 2012
	    Latest post 08-15-2009 1:55 PM by  Ehlerz. 16 replies.
								        05-02-2009 7:54 AM
									        d4vidl4ur4
								                - Joined on 05-09-2007
								                - Posts 3
										    New 40" BeoVision 7 Blu-ray
Has anyone seen the new 100hz BV7-40?  Is it close to an Avant with an SD signal?  Prices go up by 10% on 8th May so I am wondering whether to get in quick and upgrade my 4 year old BV7-32.  What do you experts advise?
David
									        Russ
								                - Joined on 05-07-2007
								                - Washington, DC  USA
								                - Posts 641
										    Re: New 40" BeoVision 7 Blu-ray
										    As far as I know there aren't any available to be seen; you're going in blind on this one.
									    We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA  USA
									        moxxey
								                - Joined on 04-14-2007
								                - South West, UK
								                - Posts 2,360
										    It's not shipping yet, sadly. 'May' was the last info I received from my dealer and that was a couple of weeks ago. Perhaps later this month?
I don't expect a significant upgrade beyond the current BV7-40 MKIII.
BTW no LCD screen is going to be as good as an Avant with strong SD signal. CRT TVs smooth the image somewhat, whereas LCDs show every flaw 'as is'. With SD on your LCD screen, you'd be disappointed compared to an Avant.
A BV7-40 will excel with a HD source (ie. Blu-ray). The big advantage of a flat-panel over CRT is the size of the screen. ie. CRT can't do 40", 50", 65" and so on.
									        d4vidl4ur4
								                - Posts 3
										    What does the move to 100Hz add?
									        KingOfSnake
								                - Joined on 02-07-2008
								                - Posts 359
										    FYI, the price rise of 10% is active from June 1st, any dealer telling you otherwise is either hard-pushing to get you to buy now or profiteering!
									        moxxey
								                - South West, UK
								                - Posts 2,360
										      d4vidl4ur4:
It improves the camera panning slightly, when watching football - ideal for me. If you only watch news and documentories, probably not a great deal! As I said, I don't expect to buy a MKIV panel and see a big improvement over the MKIII. I am upgrading the panel though.
Koning - you might be right. I heard that B&O have quite a few in-stock MKIIIs to shift before they can allow people to order the MKIV.
									        meandmyshadow
								                - Joined on 04-17-2007
								                - Posts 339
										      KingOfSnake:
Be careful about such a statement, the general price rise is indeed the 1st of June, but BV7 40 will go up on May 8th and not June 1st.  If you have an order in place now you will benefit from the current price.
									        rednik
								                - Joined on 06-29-2007
								                - Posts 150
										      KingOfSnake:
Not true.  The price increase for the 7-40 BluRay is from 9th May as stated above.  Anybody telling you a dealer who quotes you the increased price from that date is trying it on, is mis informed.
									        Flappo The Grate
								                - Joined on 04-16-2007
								                - Posts 703
										    then again since it's all in one , it's not bad vfm at all really
bd player , dvd upscaler , 4 hdmis , 3 rgb scarts, 100hz - not a bad spec at all !
i just looked up the bravia site ( couldn't make head nor tail of the thing - so badly designed ) their stuff isn't so cheap plus you'll have loads of lovely boring boxes wired up all over your house !  eeeurgh..
they couldn't explain to me which was the better model , the z , the x , the ex , the zx or the xyz with added exz-zness
									        robbykhu
								                - Joined on 07-30-2009
								                - Posts 2
										    i have a bv 7 40 mk 4. the tv has only two useable hdmi sockets. the other two are used by the tv, for the blu ray and freeview box i expect. imo, this spec is not good vfm, since you can get a better spec at roughly 6 and and a half times cheaper! even if it means you've got loads of boxes and wires all over the place...but if you can afford it...
									        Ehlerz
								                - DK
								                - Posts 510
										      robbykhu:
I have a MK IV as well, and to be fair, yes the Tv only has 2 available HDMI sockets, however there are 4. To compare with other brands you have to deduct 2 HDMI inputs for BD and DVD-HD (if one is not inbuildt) to get the same features. I know this is individual, but i will not need more than 2 extra inputs. I would instead like there to be a digital output for my Bl5´s for sound hooked up with HDMI... I dont get why this is not present?? What if you played your Cd´s on the tv, you are not able to fully use your lab 5´s possibilities. I mean, how hard could it be to have ONE digital output..???
									    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
									        BeoNut1
								                - Joined on 08-19-2007
								                - Mobile, AL (USA)
								                - Posts 226
										    Ehlerz,
If the BV-7 had this, Apple aficianados like me would completely bypass a B&O audio system by using the BV-7 as an audio master (to which we'd connect things like an Apple TV).
B&O's seemingly purposeful omission of this ability on their high-end TVs (which could be incorporated via the simple and logical addition of a digital co-axial output to the BS3), is IMHO a bad decision on their part.  I understand their apparent reasoning (i.e. protecting sales of audio master units like the BS5), but I think it a short-sighted decision that will ultimately cost them sales.
									    Mark D
									        Kokomo
								                - Joined on 08-21-2007
								                - Spain
								                - Posts 618
										      d4vidl4ur4:
More Hz?
									        Ehlerz
								                - DK
								                - Posts 510
										    My dealer just confirmed a DVB-HD update in about 2 weeks. Hopefully this fixes trouble with slow switching, restarts, showing the right programs on the right time, and occasionally displaying a big grey "cant dekode" box even if the program is present.
Lets cross our fingers
									        Carl Sheerman
								                - Joined on 04-19-2007
								                - Plymouth UK
								                - Posts 173
										    I presently have the sd freeview built into my BV 7 Mk III.  The interface is slow and sometimes take an age to populate with the programs.  Will this upgrade enable me to receive freesat or indeed freeview hd when it is broadcasted in the future?
									        Ehlerz
								                - DK
								                - Posts 510
										    Hi Carl
Dont know if the update will also include other dvb modules sorry..
        Page 1 of 1 (17 items)
