Latest post 02-16-2009 7:44 AM by zazouzt. 3 replies.
Page 1 of 1 (4 items)
  • 02-05-2009 7:36 AM
    • zazouzt
    • Top 500 Contributor
    • Joined on 04-17-2007
    • near Strasbourg/France
    • Posts 123
    Beomaster 3000-2
    My old Beomaster 3000-2 works well,  except with FM Radio where i have only one channel workin.
     When i use the TAPE entry i have  stereo, but with radio it doesn't work.
    This happens since last summer. I travelled a lot with my beomaster  ( 2000 km in a trailer...)
    What could be wrong ?
    Thanks for your help
    Théo
  • 02-05-2009 7:58 AM In reply to
    • richtoy
    • Joined on 09-20-2007
    • Valkenburg, Netherlands
    • Posts 184
    • Gold Member
    Re: Beomaster 3000-2
    Hi Théo
    Your BM3000-2 may have dirty switches or may need a capacitor kit.  User Dillen can supply one of these kits with very informative diagrams showing where the capacitors go.  If one channel is missing from all FM presets and the manual FM then it is most likely to be a capacitor problem.
    Regards
    Richard
    Some of my B&O: BV3/32, MX7000, MX5500, LX5500, MX4000, BM8000, BM6000, Overture, BL8000, BM6000 Quad, BM4400, BM3400, BG-CDX, BM3000, BM1001, BM1200, BM1600, BM1700, BM1500, BM1400, BM2400, BM2300, BM4500, BM4000, BVM70, BVS45-2, BVS60, BC7700, BM2200, BM1900, BG8002, BM1202, BVPenta, BVP45
  • 02-05-2009 7:59 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Cracked solders at the frontmost edge of the tuner board where (I think 4) metal loops take the signals to the switchbank board.
    Alternatively, the switches themselves.
    EDIT: It's true that capacitors cause many problems, a kit is available and it's recommended to replace the lot, though in this
    particular case, there are not really many electrolytic caps in the signal way that only serves the signal from the tuner.
  • 02-16-2009 7:44 AM In reply to
    • zazouzt
    • Posts 123
    Hi All,
    I opened my beomaster but i couldn't solve my problem. Sure i should have disassembled it entirely but it's not very easy for me, ( i'm afraid not to re assemble it correctly).  So what i saw didn't give me any indication of what is wrong.
    So worse, i'll stay with as it is.
    Many thanks for you comments
    Best Regards
    Théo
