Latest post 02-10-2009 12:37 AM by Cleviebaby. 6 replies.
Page 1 of 1 (7 items)
  • 02-09-2009 3:36 PM
    Beosystem 2500 and Beolab 4000
    I have an early Beosystem 2500 with the original Beolab 2500 speakers.  I want to buy an early pair of Beolab 4000s (Non ICE) to replace the BL 2500s.  Are there any compatibility problems particularly with 'Powerlink' cables?
  • 02-09-2009 3:41 PM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Re: Beosystem 2500 and Beolab 4000
    No problem. Only later BL4000 (ICE Power) need PowerLink cables MKIII (5 wires)
  • 02-09-2009 3:49 PM In reply to
    Gerd is correct, although I would always recommend that if you still have the original mark 1 cables (VERY thin, c.2mm diameter) then when you replace your speakers, this is a good time to go for some new mark 3 cables anyway.  The mark 1 cables are not the most robust option and if you are burying your cables in walls or ceilings, mark 2 or 3 cables give you some "future-proofing" if you make changes further down the line.
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
    I thought it was 4 wires :)
  • 02-09-2009 3:53 PM In reply to
    Only 4 wires plus screen are required for mark 3 cable (left and right audio, voltage reference and mute) plus screening conductor.  The fifth wire referred above to is the screen/audio ground.
    Best regards,
    Steve.
  • 02-10-2009 12:36 AM In reply to
    Thanks Steve that's really helpful
    Cleve
  • 02-10-2009 12:37 AM In reply to
    Thanks Gerd
    Cleve
