Latest post 01-29-2009 1:32 PM by soundproof. 3 replies.
Page 1 of 1 (4 items)
  • 01-29-2009 9:24 AM
    • garry
    • Not Ranked
    • Joined on 12-18-2008
    • Posts 1
    • Silver Member
    pin code
    i have just moved in to my new houes and there is a beovision 7-32 on the wall and when i turned  it on it is asking for a pin code i cont get it from any place how can i get it or get past it thanks
  • 01-29-2009 9:29 AM In reply to
    Re: pin code
    Your dealer should have given it to you when you bought it. You have to call him, or contact B&O directly for a master code.
    JK
  • 01-29-2009 12:34 PM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: pin code
    Just contact the previous owner or whoever bought it - they'll be able to obtain the pin from the dealer or B&O. You won't get anywhere without proof of ownership.
    If you think nobody cares, try missing a couple of payments.
  • 01-29-2009 1:32 PM In reply to
    Re: pin code
    garry - if you're living in an area where B&O equipment has been installed in all the housing units, then the developer should have the pin code, or they should even be in the documents you've received.
    If not, and if it's an official B&O installation, then the dealer that did the enterprise will be able to help you out. Just get the serial number of the TV and get in touch with them.
