Latest post 01-26-2009 3:47 PM by Steve at Sounds Heavenly. 8 replies.
Page 1 of 1 (9 items)
  • 01-26-2009 8:12 AM
    Beolab 8000 + non-B&O sources
    Hi
    I have just inherited a pair of Beolab 8000 and would like to know the best way to link them to a non-B&O source
    Greatul for rapid answers
    Morten
  • 01-26-2009 8:52 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Beolab 8000 + non-B&O sources
    First off, welcome.
    I have the reverse of you're situation, I have a BeoSystem4500 which now runs JBL floorstanders. I run the B&O signal through a Yamaha Natural Sound R-7, which then makes the connection possible.
    For you, however, things should be much easier. As familiar as I am with B&O speakers (not with the BL8000 unfornutely), they should also be able to be supported by two bare wire leads in addiotion to the power link. The only  B&O speakers that I know for sure that have this feature are the BeoVox 5000s.
    I'm sure more informative replies will follow.
    Evan
  • 01-26-2009 8:58 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    I forgot to mention earlier... I would contact you're B&O dealer. They are especially informative on new/current product lines. They also have the connection to the miriad of adapters made in Europe.
    Evan
  • 01-26-2009 9:42 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Using RCA/Cinch cables and the pre-out of your amplifier (so - non amplified output), in theory. Not all AVR work, for example. I always had a hum I couldn't get rid off.
    But worth a try!
    Remember to set the speakers to line!
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 01-26-2009 10:39 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Yes.
    Also I believe switching to "line" mode renders the speakers as passive, they will no longer be active as they will be solely powered by you're receiver or what have you.
    Evan
  • 01-26-2009 11:14 AM In reply to
    • kallasr
    • Posts 1,077
    No, this is not true! You use pre-outs to line-in.
    Ralf
  • 01-26-2009 11:34 AM In reply to
    Thanks to you guys for helping out
    Great help
    Morten
  • 01-26-2009 11:43 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Oh, excuse me. I am only referring to things I have heard.
    Evan
  • 01-26-2009 3:47 PM In reply to
    Ralf is correct, the Beolab 8000 remains active when in Line mode, the difference is that they no longer switch on when the B&O source triggers them.  Instead, they listen for sounds through the audio channel and switch on automatically, staying on until the music has been silent for 3 minutes, when they go back into standby.
    They do need to be connected to volume-controlled pre-out (ie. non-amplified) sockets to avoid damaging the speakers.
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
