How do you test a playback head? At the moment I ma trying to fix a Beocenter 2200 I was given. Last night I fitted a new set of drive belts (Thanks Martin
) Now I can only get sound out of the Left channel. All othere sources work ok and I have swapped the two connectors over that come form the playback herad. This causes no sound in the Right channel instead. The wiring is fine between the head and the connectors. Although I always thought when a head went down on one channel you got strange ohm readings accros the head. Tested both channels and got a readings of 212.3 and 212.5 Ohms.
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
