Thanks Spiros. I forgot about the manual. I have red it now and the entry I have tried yesterday should be the right one.
Menu AV Board, then M2 Information. It is the following option:
STB TIMER Is default set to 0 but can be altered if timing problems occours during start up with certain Set-top Boxes.
Yesterday I tried this. The number can be between 0 en 255. Not known what it represents (seconds, minutes, or something else).
I have tried number 2 (suppose it represents minutes). Result: nothing
I have tried number 60 (suppose it represents seconds). Result: decoder did't start and the 'record' indicator on the HDR-2 was flashing. No recording was made.
So I am on track, but what is the right number???? I don't know. It is a lot of work to try the all (255 numbers).
Does anyone know the right number and what it represents??
Piet
