if your BeoSound 3000 is the large clamper version, you could consider connecting a BeoPort…
It is a more expensive solution, but you will be able to control your pc with the Beo4 remote, and you will get access to a lot of Internet radio stations.
Regards,
Erik
My Beo: BeoCom 6000, BeoCom 2500, BeoCom 1401, BeoLine, BeoVision LX6000, BeoVision LX2500, BeoVision MS6000, BeoVision MX4002, BeoVision MX1500, DVD1, BeoSound 3200, BeoSound 1, BeoLab 4000, BeoGram 4500, BeoPort, BeoPlayer, 3x Beo 4, 2x BeoLink 1000, V Terminal, Form 2, Light Control 2, BeoTime
