Latest post 01-14-2009 12:00 PM by The Plumber. 5 replies.
Page 1 of 1 (6 items)
  • 01-14-2009 7:44 AM
    Infra red eye
    Hi Gang,
     More advise required! See this infra red eye? well the one i have doesn't have the beveled bit on the back which i assume is for easier mounting when the cable is to be built into the wall. Is this correct and can it be bought as a spare part? If so would anyone know the product number?
    Thanks in advance.
    Mark.
    Never Mind The Ball-Cocks www.markmossplumbing.co.uk
    A labourer uses his hands
    A tradesman uses his hands and his head
    A craftsman uses his hands, his head and his heart
  • 01-14-2009 8:45 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: Infra red eye
    Hi Mark.
    i use an ir-eye because of the ir-radiation from the flatscreen.
    Yes, can be ordered as spare part.
    Part no: 8087030
    It doesn't have the buttons on it (like on the image), it's just the ir-eye.
    I'm not 100% sure if that is the one you are looking for.
  • 01-14-2009 10:23 AM In reply to
    Re: Infra red eye
    Yes it can be ordered as a spare although I don't know the part number. It's used for building the eye into a plasterboard wall.
    My dealer ordered it for me around 9 months ago. I remember being surprised at the price!
    Regards Graham
  • 01-14-2009 11:00 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Re: Infra red eye
    If it is just the ir-eye that is needed, the above mentioned 8087030 is the one.
    Price is about € 40,- if i remember correctly.
  • 01-14-2009 11:27 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: Infra red eye
    Hi Mark
    I think that what you are after is the mount bracket for the IR sensor not the sensor itself. The part number for the mount for a plasterboard wall is 3375188.
     I tried to upload an image of this item but I'm afraid technology got the better of me.
    Regards
    Opman
  • 01-14-2009 12:00 PM In reply to
    Re: Infra red eye
    Thanks lads, excellent as usual. Yes it is just the mount bracket that i need (i have the eye). I will contact my dealer to order one.
    Cheers
    Mark.
