Latest post 01-13-2009 12:30 PM by Craig. 1 replies.
Page 1 of 1 (2 items)
  • 01-13-2009 8:49 AM
    • meling0017
    • Not Ranked
    • Joined on 11-18-2007
    • Stavanger, Norway
    • Posts 18
    • Silver Member
    Use of AudioAux link LX 5500 with other TVs
    I used this cable to connect my Beosystem 5500 to the Lx 5500 tv.
    I now have a Beosystem system and changed the LX 5500 with another brand flat screen tv. The plug that was used in the B&O tv seems to be be 7 pin one and goes directly to the Beosystem amplifier. My question is if it is possible to extract the loadspeaker cables from this plug and connect to the BO 7000 as before in the back of the 7000 amplifier, and only connect these cables to the new tv aux out alternativly the DVD aux out and can I then transfere the sound to the 7000? I realize that I can not control anything from the TV but can the signals be transferred as decribed so that by switching the 7000 system to TV he sound will be there.
    Henry
    Filed under:
  • 01-13-2009 12:30 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Use of AudioAux link LX 5500 with other TVs
    Your new TV has most likely got Phono connections for connecting to an external amp. If so you just need a Phono to 5 pin DIN lead.
    CraigSmile
