kokomo: Hagen2000: Hi,
I would like to know if there is a reset sequence for an LC2 dimmer, i.e. to reset it to factory defaults, clear individual numbering etc.
Is any information available, what the actual firmware version of the LC2 should be and what corrections have been done in the firmware?
Thanks!
Don't quite follow what you want to do and why. Do you want the LC2 not to respond to any number whatsoever and just respond to Light Light without having any number allocated? Why wouldn't you want to allocate it a number or change it from its present one?
1. Yes, I want to be sure that there is no individual number assigend to the LC2 (setting it to number 0 seems to work but the manual doesn´t mention this). May be there are other parameters that need to be reset. That is why I asked for a reset sequence. B.t.w. LIGHT LIGHT always addresses all LC2, their individual numbering is irrelevant in this case.
2. A second reason is that one of my LC2 seems not to react to the sequence LIGHT GOTO 0 STORE 1 - programming the on/off function to "off". After disconnecting and reconnecting the mains, the lamp is lit up even though it shouldn´t.
3. The LC2 seems to be able to "remember" the brightness level that shall be activated when power goes off and on again. I assume that there exist further programming steps not explained in the manual to control this function.
4. In the english manual I found also LINK LIGHT pictures that are not explained in the german manual.
