So I've tried some stuff I found on the web but nothing worked.
Anyone got any idea how I can open my DVD1 B&O to be multi-region player?
Thanks in advance!
Maybe someone tried this before:
http://www.jvbdigital.nl/jvb.asp?cur=2&level=modifications&page=title&title=8
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
Its about a 5 minute job once you have the instruction list and a suitable remote control (Beo4?).
It can take a couple of attempts to 'take' but relatively simple if you have the instructions.
I suggest you find a tame engineer.........
Train Hard - Run Fast - Hit to Kill!!!
I also took it to some lab and they're having hard time finding it, they have the code but for some reason it simply doesnt work. They still managed to change zones if they tried, but the multi-zone hack simply doesn't work.
Anyone got more ideas?
Avi, do you bave a B&O service centre near you? If so, take it there and they can do it on the spot for not much money.
Good luck
My B&O: 2009 Catalogue and Pricelist
Ok they've fixed it!
