Improvements
New B&O products added:
• DVB-HD.
• BeoVision 7 no DVD.
• Preparation for BeoSound 5.
Engine improvements, less or not visible to the user:
• Major changes in the internal architecture of the tool software.
• Serializer efficiency is improved in terms of binary size, leaving more space for e.g. logos.
• Error corrections on both tool and firmware improving support for 3-party IR.
Errors corrections:
2 A-rated errors, 23 B-rated errors, 20 C-rated errors, and 16 D-rated or not classified errors. Totally 61 errors.
Emphasised corrections:
080905          Not able to change speaker mode in N.MUSIC/N.RADIO.
085485          "Text" button missing within Text menu on DTV and VMEM source.
085763          AV-sources not available in link room.
085399          MENU not sent with link bit on bl3500 in option 4.
084134          If you change the name of the speaker modes they no longer work.
076113          Serialization error when using BC 2-MKII with BeoCenter 6 in the same zone.
082532          Error deleting delays in macro.
085293          No DVB-T for BeoVision 8.
081020          Imported configuration is not stored correctly.
082540          V.MEM separated into V and MEM.
076541          Serialization failed when a channel number is 0 or bigger than 65535
078833          Serialization error when moving /TV/ button.
