Hello Ben,
As far as I know, you installed your Beoport in the right way.
It works fine for years now in my setup (I have a Beolink PC2, which is the previous version of Beoport. It's exactly the same product, only the name changed).
You should be happy with it, no matter which cables are used.
BTW, Beoport is not designed to send video signals through ML (Video is sent through standard coax antenna cable).
To summarize:
- You can only transmit music to your system (N-Music, N-Radio and PC-CD ) through the minijack cable),
-  ML is used for the control of Beoport from the main system or of remote sources on your PC (audio and video if you have a supported graphic card, which means that your PC is rather old).
- USB is used for control of the Beoport by the PC.
- The "photo" part of the software is for PC use only.
Yann.
									    Ne pas s'en faire et boire frais!
Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
