Hello,
I have got a problem using the Beo5 for controlling the DVD2 (connected to an Avant). Although it is possible to use the arrow up and arrow down keys to switch between TV channels in the TV mode (the built in tuner of the Avant), I am not able to switch the channels at the DVD2 using the arrow keys.
One of my reasons to purchase the Beo5 was the wish to control the DVD2 in an easier way than with the Beo4. Actually it is easier now to choose a TV channel by the logo (than knowing the number) and to start a recording, but I am unhappy that I cannot use the arrow keys any more.
Using the Beo4, the arrow keys work as they should even with the DVD2.
I wonder why the Beo5 is refusing to send the right IR commands. In the configuration tool I see no option to configure the commands for the arrow keys or for other keys on the wheel. Therefore I suppose that the commands send by these keys are always the same. Or does the Beo5 deactivate/change the IR commans for some of these keys depending on the current mode?
The problem seems to be known by B&O anyway, because the default button page for the DVD2 shows a "channel +" and a "channel -" button. There would be no reason to offer these buttons if the arrow keys are working. But what is the reason to disable a feature that did already work on Beo4? Or did I make a mistake in configuration?
Can anyone help?
EDIT: Now I've heard that the kind of IR signals send out when pressing one of the hardware buttons seems to be controlled by the hardware component choosen via the softbuttons on the touchscreen. As the DVD2 supports Beo5-IR-language other signales are used when pressing the arrow keys for example than in the Avant mode. Is that right?
If yes: might there be a possibility to configure the DVD2 as an older device (DVD1, VideoRec) and edit the IR codes of the softbuttons manually then?
