Hi all,
I have got back an old beomaster 6000 (type 2251) and I have checked it.
First, in the amplifier part, some capacitors which are C201, C202, C215 have melted and a resistor R221 is cut. I think it's due to a problem of overloading or bad capacitors and I will fixe that later since the other problem is more boring.
Then, the second problem is that the beomaster doesn't want to switch on when I pressed a FM preset button and so on...I have just three points which are lighted, on the screen used to indicate the FM tuning or the hour, and the lamps used for the balance: IL3 are slightly lighted and IL4 very well lighted.
I have the schematic diagram and I have checked if TR16 for instance for the preset P1 has the information when P1 was pressed and it's the case. And I have also noticed that on the card16, at the collector of TR4, I don't have 5Vpp but far less although I have 1Vpp on its basis. And I have replace TR4 but the same thing occurs!
So I don't know if there is a problem with the µcomputer (I hope it's still OK) or others components.
Can someone help me?
Thanks in advance.
Regards,
Mathieu
