BeoVox 3000 Passive Loudspeakers Product Specifications
Type 6220
Dimensions W x H x D 63,5 x 28 x 30,5 cm
Weight 12 kg
Performance
Music load 60 watts
Continuous load 40 watts (DIN 45,573)
Frequency response 28 - 20,000 Hz (DIN 45,570)
Distortion Max. 1,5 % (DIN 45,403)
Sensitivity 4 watts (DIN 45,500)
Crossover frequency 2000 Hz
Capacity 37 litres
Resonance of woofer 24 Hz
Dispersion 120°
Number of units
Bass unit One 25cm
Tweeter One 2 DOME
Connections: Output Tweeter - 4 ohms
Input DIN socket - 4 ohms
Weight 12 kg
Beovox 3000 Specifications type 6238
Performance
Music load 60 watts
Crossover frequency 2 kHz/10 kHz
Capacity 37 litres
Dispersion 120°
Number of units
Bass unit 1 - 25cm
Mid-range 1 DOME unit
Tweeter 2 -5cm
Connections: Output Tweeter 4 ohms
