Latest post 06-19-2008 11:21 AM by yachadm. 3 replies.
Page 1 of 1 (4 items)
  • 06-19-2008 6:52 AM
    • Ben
    • Top 500 Contributor
    • Joined on 12-28-2007
    • Taunton, UK
    • Posts 131
    • Silver Member
    RIAA Preamp in Beomaster 3500/4500
    I was looking in the service manual with regards to the RIAA option. From what I can tell, this consisted of an add-on module inside the system, is this correct?
    I was hoping that it was just an unpopulated area of the main PCB, but I guess this isn't the case.
    I didn't really want to use an external amp, as the system will be mounted on the wall, and i'll be using a Beogram 3000, so there's no preamp in there.
    Any ideas?
    Cheers
  • 06-19-2008 7:16 AM In reply to
    Re: RIAA Preamp in Beomaster 3500/4500
    I had a BM4500 with the RIAA module but can not tell you any more than that. All I know is that it cost £15 extra when new!
  • 06-19-2008 8:42 AM In reply to
    • Ben
    • Taunton, UK
    • Posts 131
    • Silver Member
    I'd buy one now for £15 if they were still available!
    Looks like i'll have to use an external one and hide it behind the wall brackets somehow.
    Ben.
  • 06-19-2008 11:21 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Hi Ben,
    In the 1999 B&O Accesories Catalogue, on page 13, are listed 2 RIAA Preamplifiers
    1. Part 8002956 for the BeoMaster 3500/4500
    2. Part 8001245 for the BeoMaster 6500/7000
    Now, the challenge is to find one!
    And then to upgrade the capacitors and OpAmp, and THAT will be an RIAA amp worth listening to!
    Regards
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
