Hi beoworld!
You have all been very helpful with my selection of equipment for upgrading my home entertainment system. All the equipment has been ordered, and now it's down to finalizing the placement of the TV (BV7-50) and center (BL7-2): either on shelving unit or wall mounted. Time to buy some furniture!
There are two options we are considering.
Option 1 places the TV and center on a shelfing unit.
The issue here is that the center would have to be located above the TV. TV would be about 29 inches/74cm from the floor, center about 73 inches/185cm high. TV will be on the B&O stand. Center will be wall mounted above the top shelf.
Question: is there anything inherently wrong with placing the center above the TV? Is this too high to place a center? Is the TV too low?
Option 2 wall mounts the TV and center above an equipment cabinet. TV would be about 38 inches/96.5cm from the floor, center would be mounted below the TV, about 28.5 inches/72.4cm high.
Question: is the TV located too high in this set up? (It would be about 10-12 inches higher than the other set-up)
Seating in either option is on a "normal height" sofa and about 9 feet/2.7 meters from the TV.
I have attached some rough renderings of both set ups, neither is partcularly to scale, but it will give you some idea of the set-ups. (The grey thing with 5 circles is a BS9000. I know there are 6 cd's in the BS9000, I just was tired! The TV and center are labeled.)
Link to renderings:
http://snipurl.com/1kegz-KCHI2B
As always, I appreciate your candid advice, input and recommendations.
All the best~~
Todd
(sorry if my metric conversions are off, it's been a while...)
