I am silly to try you think, but this is very important to me!
The iPhone has a component AV cable with Y Pb, Pr coming out which look like red green and blue plugs to me, and then there is red and white audio sound.
So I tried to hook this up and make it play. On the TV, there is a set of component video jacks on the back, colored red green and blue, say Y Pb Pr, up near the top, and then the whole row of various video and audio inputs on the bottom.
I hook up the Y Pb Pr on top then the two audio red and white to the audio red and white inputs on the bottom for STB. (I don't use a set top box, I just have a DVD player for my TV, no cable.)
And when I set to play STB on the remote, then I can hear the sound, but see no picture.
I try to figure out on the remote control menu, the place where you say what the input for which external source are, and I select for input for STB that it is generic YPbPr, so that should work, I think, but the screen is just black, and I just hear the sound, no picture.
Is this too silly easy or ridiculous to try? I really don't know. I just really want to watch certain movies I have. Help? Thank you thank you so much.
xie xie
