BeoLink
Wireless 1 updateSet-top Box
CoverBeoLab 6000 wall bracket
With the new wall bracket for the BeoLab
6000 loudspeaker, sound has been given a whole new dimension.
The
BeoLab 6000 wall bracket allows you to mount the loudspeaker on a wall, opening
up new possibilities for placement in the home.
The
wall bracket is comprised of two parts: an oval ring onto which the loudspeaker
is mounted, and an l-shaped bracket that connects the ring and loudspeaker to
the wall. The ring and bracket are made of pearl-blasted aluminium, and on the
ring is a front plate made of brushed aluminium.
The
bracket allows you to mount the BeoLab 6000 on the wall in a vertical position.
The Power Link and mains cables are led neatly and invisibly from the base of
the loudspeaker through the bottom section of the bracket.
Questions
and answers
What colours are available for the BeoLab
6000 wall bracket?
The
wall bracket is only available in one colour, aluminium, to provide an
aesthetically pleasing contrast to the BeoLab 6000 colours.
Technical specifications
Designer
David Lewis
Size (HxWxD)
25 x 9,6 x 13,8 cm(10 x 3.8 x 5.5”)
Weight
0.7 kg (1.5 lbs)
Material
Aluminium
Type number
2157
Bang
& Olufsen preliminary price (does not include VAT)
228 Euro per set
See the attached image file.
HTH.
Pedro
"Less is more"
BV7-40 MKII + BL7.2 + BL9 + BL3 + BS4 + BL4 + A9 + Earset 2 + 2 x Beo4 +
BeoCom 5
