beocool:
Stan: And I'm going to guess that
Since that is what my new Beo4 has.
Stan
I thought 21 would be more likely... On the sticker are two numbers. The lower one is the serial number and I suspect the other one is the product number. Hope this helps...
No, since neither number matched your list, I double-checked against an older Beo4 to verify which number was which... my top number is 8052757, the lower number is 0037xxxx (xxxx are actual numbers, but I don't like broadcasting my serial number... not that I can think of anyway that it would matter :)).
I would agree that this is odd. Maybe 21 was already used by some other product?
Stan
