Sometimes, the Beogram keeps playing even if lift is pressed, only the lamp lights up. This is very common to see, also in the Beogram 3000. It's a fault per construction and is not something a replacement "solenoid" will fix. The only solution is to lift the tonearm manually and set it down at the end of the record. It will then lift, park and stop automatically.
