My Dad's Beomaster 1000 needs a full set of lamps.
The tuning
scale lamps are not a problem - Maplins sell BU19V R10 MES 6.5V 300mA
which is as near as makes no difference. Sorted.
The stereo indicator is stumping me though. It's a 19Volt 0.097Amp,
PHILIPS 8097D/71 IMPX (part number 8230004), should be common as muck
because they were used in all sorts of old radios, but I can't find one
anywhere. Nearest matches I found were also from Maplins - either a
BU20W R10 MES 12V 100mA or a BU21X R10 MES 12V 183mA. (They do 24V
flavour as well, but I thoughtthey might be a bit dim - 50mA and 125mA rated.)
Ideally I'd like the proper replacement, but I gather they are
unobtainable. Failing that then, which of the contenders I've found
would be the best option? Or should I get one of each and try them and
see?
Many thanks in advance,
Steve
