Latest post 02-20-2012 4:42 PM by sonavor. 215 replies.
Page 4 of 9 (216 items) « First ... < Previous 2 3 4 5 6 Next > ... Last »
  • 01-13-2012 9:59 AM In reply to
    Re: Beomaster 6000 Refurbish
    Thanks for the encouragement.  The information in the links look promising.  I will have to dig into the potentiometer and check all of those connector solder joints later today.  I did check the voltage on the reset line and it is measuring 4.9vdc.
    -Sonavor
  • 01-13-2012 11:33 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Hmm that is not really what you wanted to see. I would expect to see closer to 5v but I really don't think 4.9v would be problematic, Where did you place the meter negative?
    The fact reset is high, means that the processor should be running ok, at this point try shorting test points and see if pin 39 drops to zero volts (not that it makes a great deal of difference!). Are you sure you got the right pin? Also check that the micro is getting a supply by testing accross pins 20 & 40.
    I would check all the work you have done in this area, and double check the electros (did they go in the right way?) and look for bridges, dry joints etc. you really need to download the service manual if you haven't done so already.
    What are you taking in the way of antistatic precautions?
    Olly.
  • 01-13-2012 11:50 AM In reply to
    Step1:
    Not necessarily; the reset signal needs to come up with a certain speed and timing in relation to the supply voltages, or the processor might not reset properly. Just having it high at a later time isn't enough.
    The reset circuits in many B&O products are implemented in a somewhat odd and complicated way for whatever reason (compared to what the chip manufacturers specify) and aging components may cause them to not work properly. Could well be a problem with the trimmer now that the circuit board has been disturbed.
    -mika
  • 01-13-2012 12:13 PM In reply to
    When I get back to it this afternoon I plan to monitor the reset line with an oscilloscope so I can see activity on that signal.  I did first check the voltage from pin 40 V+ and pin 20 gnd.  It was also 4.9vdc.  After that I checked the reset line...but only with a DVM to see what the current state was.  Dillen also mentioned the trimmer involved with the reset logic so after I see what the scope reveals I might have to change that out or try to re-adjust it.  I am also going to check all of the board connector solder points.
    -Sonavor
  • 01-13-2012 12:19 PM In reply to
    On the antistatic precautions - I didn't wear a ground strap on my wrist to my anti-static mat.  However, I did make sure I touched chassis ground before touching the board.  The only components I removed on the board were the IC8 and two electrolytic caps.  I double-checked the caps first thing and they are in with the correct polarity.  I haven't done a complete inspection of the solder joints yet.  I do have the manual.
    - Sonavor
  • 01-13-2012 1:28 PM In reply to
    I couldn't wait to check the signals on a scope so I did a quick measurement over lunch.  Here is a picture of what my oscilloscope caught monitoring the micro-computer - IC4 on the 02 Module.  The red trace is the probe connected to pin 40 (Vp) and the yellow trace is the probe connected to pin 39 (reset).  Should there be more of a delay when the reset line comes up?  Also note - in my earlier posting where I said the DC voltage was 4.9...it is actually 4.98.
  • 01-13-2012 1:49 PM In reply to
    Another oscilloscope measurement at BM6000 power up.  This is IC4 pin 40 (power) and pin 19 (fault switch).
  • 01-13-2012 3:18 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    sonavor:
    Looks about right, I think the best thing you can do is to follow the proceedure to recalibrate the reset circuit, after replacing the preset. The reset could be opening up a little prematurely. Have you tried shorting the reset pins? - base of transistor 2tr5 shorted to ground?
    I wouldn't worry about the fault signal timing wise, this event happens before the reset signal goes high so will not effect the processor. however not sure I like the fact it is going negative for a short period. Anyone esle with other opinions?
    @Mika yes I guess more modern processors have brownout detect which is what this circuit effectively is. Now, regards the reset signal I would think a late reset pulse should be fine, as the instructions are only halted by the presence of a reset signal, the processor is still active internally according to the manual. I wonder if too early then this could be an issue?
    Olly.
  • 01-13-2012 4:33 PM In reply to
    I ran a test where I forced a reset - connected the base of TR5 (TP1) to the ground of the board.  I was monitoring the reset line (Pin 39 of IC4) and saw it go to its "0" state.  Nothing changed during or after the reset regarding the display.  It remained at "P".  Is there an output pin for IC4 that I can monitor to see if the reset line affected it?  Something to tell if IC4 is functioning?
    -Sonavor
  • 01-13-2012 10:03 PM In reply to
    I think I have found the problem.  The IC4 MicroComputer has no clock.  IC4 pin 15 is supposed to be the timebase for the processor and it is dead.  So without a clock nothing can change state.  Here is a picture of the 02 Module circuitry involving the timbase and microcomputer.  The red line is the connection that is supposed to be supplying the clock signal to IC4.
  • 01-13-2012 10:26 PM In reply to
    Here is a picture of the 02 Module microcomputer components front-side and back-side.  Note: The back-side was photographed prior to replacing the IC8 component.  I have a question about the unknown IC that is mounted on top of IC7 and IC6.  That looks like some sort of retrofit mod.  I don't see it in the schematic.  The IC components I have identified are all involved in the clocking on the board.
  • 01-13-2012 11:03 PM In reply to
    I have studying the unknown IC and the wiring it uses to the trace side.  It looks like it is a replacement for IC6 (which is underneath it).  IC7 and IC9 are 74LS93 4-bit binary counters (Decade Counter; Divide-By-Twelve Counter).  IC6 is a 74LS393...slightly different?  The replacement on the little home-made board is a 74LS74AN Dual Edge Flip-Flop.  The pin layout on the IC is different from the 74LS393 so that is why the mod with the board was made.
    Now I need to determine what exactly are the bad components in the clock signal circuitry.
    It appears Mouser carries 74LS93 and 74LS393 chips so I will look at restoring the original layout.
    -Sonavor
  • 01-14-2012 1:25 AM In reply to
    After removing the mod PCB with the 74LS74AN IC it looks like this is an official Bang & Olufsen mod.  The little mod board has a number: 8002562 that fits the B&O PCB designators.  I traced out where the wires went that attach to the small board.  I will try and trace out the whole circuit to compare it to the old IC6 4-bit counter.  It looks like the input to this mod board is the same as the original IC6 but it the output looks different.  I won't know for sure until I map everything to the 8002562 traces and the 74LS74AN pinouts.  Here is a preliminary, crude mapping.
  • 01-14-2012 5:08 AM In reply to
    sonavor:
    Not quite correct - that signal is apparently just something the software uses for timing purposes. The actual clock oscillator is in the processor, on pins 1&2 around X1 and supplies the 3.something MHz clock to both to the processor itself and the divider circuitry you're working on (via the blue trace you've drawn). Did you have anything there?
    I believe the processor is actually running as the "P" display wouldn't come up at random every time, it is probably some error diagnostic. Anyway if the divider isn't working, you'll need to fix it.
    -mika
  • 01-14-2012 8:24 AM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    This little board is an official b&o mod designed to reduce the burden of the CPU needed to read the frequency pulses from the radio section, it has nothing to do with the processor clock.
    You should be able to see a clock signal on the pins Mika suggests above, if not, I am afraid it is more than likely your processor has failed.
    Olly.
  • 01-14-2012 11:40 AM In reply to
    Yeah, I see that now.  I checked the oscillator and pin 1 of IC4 and there is a signal there.  So with a clock signal going to IC4 and +5V power, the processor does not respond to the reset line.  The display output is stuck on "P".  I think IC4 is dead.  Is the IC4 processor component still available or is this receiver now a spare parts unit?
    -Sonavor
  • 01-15-2012 1:51 AM In reply to
    Here is what I make of the Beomaster 6000 - 02 Module frequency counter circuit.  The top frame is from the service manual schematic.  The bottom frame is from tracing the paths on my BM6000 with the 74LS74AN flip-flop on the 8002562 mod PCB.  Note that I didn't include all of the +5V filtering components on my schematic.  I also didn't show all of the other connections to the IC4 processor...just the ones to and from the frequency counter.
    Looking at the circuit schematic now, it appears that I would only see clocking signals out of the IC6, IC7, IC9 and the additional IC when the FM tuner was in play?  So that circuitry might all be okay.  I was thinking (hoping) that the fact I wasn't seeing any output there that it might be causing my problem.  I don't think that is the case now.  It appears that the processor (IC4) is dead and so there is no FM or any other function alive except for the power supply. I am not giving up though.  I will put this one a way for a while until I can locate a replacement IC4 component.
  • 01-15-2012 3:38 AM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    The circuit you show above is indeed the clock advancing the micro but the signal is derived from the main processor oscillator, which is derived from the crystal / processor. If there is no activity at the crystal (and assuming there is nothing heavily loading this part, even like a solder bridge or other short etc.), the supply is ok and the reset pin is high then there really isn't anything else it can be.
    Olly.
  • 01-15-2012 3:47 AM In reply to
    I do get a triangular type 3.975MHz signal from the oscillator (on one side, the other side was 5v I think).  It isn't a nice, perfect triangle wave.  I'll try and get a picture of it from the oscilloscope.  But even so, I think there is a lot of evidence indicating the processor is dead.  If so, I had to have zapped it with static when the board was out of the unit. The worst part about that is that I do have an anti-static mat and wristband but I wasn't wearing the band.  You can bet I won't make that mistake again.
    In your Beomaster 6000 repairs, have you ever had to replace the processor chip?  Is the only way to get one to find a broken BM6000 (with a good IC4 chip)?
    -Sonavor
  • 01-15-2012 5:49 AM In reply to
    sonavor:
    Never mind the waveform over there - coming directly off the crystal, it won't be a clean signal, and even the load from your oscilloscope probe may alter it. It's very high impedance, that's why there is a FET (TR10) and another transistor amplifying it before it is fed to the digital circuits. There are a number of intermediate frequencies specified on the schematic, go through them instead starting from the amplified 3.975 MHz at the collector of TR11, where you should see a clean TTL level square wave. The dividing circuitry is completely dumb and will run regardless of what the processor is doing.
    The processor is unfortunately a mask programmed device with the program code fixed in ROM, so the only source for it is another BM6000.
    -mika
  • 01-15-2012 8:23 AM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    But at least he has a waveform which is encouranging :) Now he needs to trace to find out how far it gets like you have suggested :).
    Olly.
  • 01-15-2012 11:20 AM In reply to
    So you are saying that if the waveform doesn't make it through the digital circuit that would cause the processor to not function properly?
    -Sonavor
  • 01-15-2012 12:31 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Yes, the main oscillator is used for the internal timers to count the tuner pulses, and then that very signal is prescaled to time the processor - this is why I asked if you had a main clock, start at the roots, so to speak! If there is a clock at the gate of the fet, then there should be a clock at pin 15, if not find out where it is getting stuck.
    Are you using x10 probes? I get a fairly nice sinus wave with processor clocks generally, and that is with a no thrills scope and standard x10 scope lead (I would really love a digital scope to capture waveforms though!).
    Olly.
  • 01-15-2012 1:57 PM In reply to
    I have the little 8002562 mod PCB out right now but one reason I removed it was because I wasn't getting any clock signal at the processor pin 15.  I have ordered replacement ICs for the counters (they were pretty cheap - from less than a dollar to just over two dollars).  They should arrive tomorrow and I will get the 02 module back together.  Then we'll see what happens.
    My scope probes are switchable between x1 and x10.  I switched between them to get the best image I can use. I am using a 25MHz digital dual-trace scope.  It is Chinese made (Owon brand) and it works good enough for me.  I always wanted a Tektronix or HP but those are just too expensive for my budget. A friend of mine suggested the Owon to me and it has been a nice tool to have. They sell new for less than $300.
  • 01-16-2012 4:12 AM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Yes I have had my eye on the Rigol scopes for some time, and the 50Mhz version can be 'upgraded' to the 100Mhz with exactly the same performance as the official 100Mhz with a firmware flash!!! - I think the manufacturer became aware and changed this but there seems to be a lot of original stock left lol. Just can't justify that sort of money as I need other bits and bobs :(
    Olly.
