Latest post 01-21-2012 11:19 AM by Søren Mexico. 7 replies.
Page 1 of 1 (8 items)
  • 10-20-2011 2:53 PM
    BeoVox 2702 cone question....
    Fresh from the successful refoaming of my CX50s I decided to try and resurrect a pair of 2702s that came along with a BeoGram 1200 I bought.
    After removing the first fret it was clear to see that the surround had long since perrished so I removed the driver and began to clean it up. It was only then that i noticed the tilt of the cone and how much it was rubbing. There seems to be tighter tollerances of the voice coil compared to the CX50s - although it does seem to move freely without rubbing if you get it in the 'sweet spot' - however, the cone is not level in this position.
    If I refoam in this state surely the surround will pull the cone out of true and the coil will rub? - is there anything I can do to remedy this (the speaker cases and frets are in really good condition so want to try and save them).
    Hope someone can help!?
    2702 woofer pic 1
    2702 woofer pic 2
    2702 woofer pic 3
    Beolit 400 / BeoSystem 10 / Beomasters 1000 + 1200 / Beograms 1000 + 1200 + 1202 / Beovox RL1000 + CX50 + 2702 / Beolab 6000 / A8
    Filed under: , ,
  • 10-21-2011 1:56 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: BeoVox 2702 cone question....
    That one is destined for the bin, I think.
    Shall I see if I can find another ?
  • 10-21-2011 3:25 AM In reply to
    Thank you Martin - tonight I'll take the other driver out and see what its condiction is. If it's in a similar state to this one then I might give up on them. If its ok, however, I might take you up on your offer of locating a replacement.
    Many thanks
    David
  • 10-24-2011 8:42 AM In reply to
    Well I've checked the other driver and it seems fine so I've sent you a PM Martin!
  • 12-02-2011 8:30 PM In reply to
    • pepps
    • Not Ranked
    • Joined on 11-09-2009
    • Faversham, Kent
    • Posts 51
    • Silver Member
    I'm having a similar problem with a pair of stunning 3702s. Grinding from the coil. Worse though is the spider on mine is sort of ruffled and not flat like yours.
    If you receive any tips do PM me :)
    Thanks!
  • 12-07-2011 11:27 PM In reply to
    pepps:
    Thanks!
    Check the pics of my 3702  here which type are your 3702s 6244 or 6263, if 6263 could you check the crossover and tell me, which size are the resistors and the capacitors, or/and post a pic.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 01-21-2012 11:10 AM In reply to
    • pepps
    • Not Ranked
    • Faversham, Kent
    • Posts 51
    • Silver Member
    Huge apologies - I only just found this reply to my comment in the 'speaker refurb' thread. Sorry but my 3702s are 6244s. They're still knackered too  :(
    Filed under:
  • 01-21-2012 11:19 AM In reply to
    pepps:
    Well late but there, here is the cross over from mine. should be different in yours
