For fun I decided to re-commision an old Beomaster after many years of storage recently but unfortunately I didn't have any passive speakers to use it with. A casual glance in our local paper the other week I saw an ad for 'B&O speakers £15". Of course I called and was told they were sort of silver in colour - good enough for me. I went there thinking at worse they'll be CX50's but they turned out to be pristine aluminium C75's without a scratch or mark on them plus no foam rot or signs that there could be in the future. Although very happy with the deal I did leave wishing if only they were CX100's.
In the past I have had CX100's and these C75's sound very good too and from this and other sites I understand that CX100's superseded the C75's.
My question is; are C75's inferior to CX100's, the same or better? I ask because having read up on them it is mentioned that CX's used cheaper bits inside to reduce the manufacturing costs! That may not be correct though.
Steve
If you think nobody cares, try missing a couple of payments.
