Hello...I've been enjoying my RX2 now for about 7 years and I'm wondering if, over time, the speed of the turntable needs to be calibrated. It's seems that it's just a hair's breadth slower than it should be, and since everything is automatic with it, adjusting the speed seems like it would be difficult to do. So my questions are:
1) How can you tell if it's rotating at the proper speed? (There's a quasi-geometric pattern on the platter which I wonder if it's not intended as a way of guaging the speed).
2) How can I adjust the speed, if it is, in fact, rotating slower than it should be?
Thanks for any help/advice.
David
