Latest post 02-11-2012 5:23 PM by Stonk. 3 replies.
Page 1 of 1 (4 items)
  • 02-11-2012 2:37 PM
    • Hubbe
    • Not Ranked
    • Joined on 02-03-2011
    • Posts 35
    MX-7000 worth repairing?
    My mother has an early MX-7000 from the mid 90's. There is something wrong with it. The image is slightly blurred and there are diagonal stretch across the screen. It is something that seems familiar? I have seen that you can buy cheap MX televisions. An alternative would be to buy a used 32 "Avant. It's probably not economically feasible to repair it. But that option is not excluded. What would you have done?
  • 02-11-2012 2:55 PM In reply to
    Re: MX-7000 worth repairing?
    As far as I know the problem you discribed can be caused by two problems. One is a defective picturetube, in that case it is not worth repairing. But this is almost never the case. I think there is a problem with the G2 trimmer, this is located on the PCB that is on the picturetube. And that's an easy fix.
  • 02-11-2012 3:28 PM In reply to
    • Hubbe
    • Not Ranked
    • Posts 35
    Thanks, maybe worth to have an B&O technician have a look at it and take it from there. I don´t have any skills to do anything myself.
  • 02-11-2012 5:23 PM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Armed with the information above any decent TV repairer should be able to carry out the workSmile
    If you think nobody cares, try missing a couple of payments.
