First question: Does the capstan turn when the recorder is on?
Secondly, Did you install the belts the right way and is it the right kit?
The head block won't be kept engaged if the tape doesn't move at all as it senses that the tape side has played to it's end. Can the machine engage in rewinding?
-Søren
									    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
