jkhamler:
Is there a way to definitively check, via means of diagnostics/software versions etc. if the set is capable of doing this?
As already posted in your other thread:
The 4 digit TYPE NUMBER would help ...
You can find this number:
1) on the rear side of your tv (hidden under the cover for the connectors)
2) by entering the service menu
