1st March February 2012
Latest post 10-07-2011 6:16 AM by olvisab. 17 replies.
10-05-2011 3:05 PM
olvisab
- Joined on 06-17-2009
- Posts 39
can't select "pc" with my Beo4
Hello everybody
I would like to select the DVI input of a bv6-22 with my Beo4 and I didn't see the "pc" option when I push "list" several time.
Is there another way to access to the DVI input through a menu on the tv or any button on the beo4?
THis is a basic bv6-22.
Best regards
oLivier
elephant
- Joined on 04-16-2007
- Melbourne, Australia
- Posts 2,215
Re: can't select "pc" with my Beo4
Perhaps your Beo4 is downlevel and could do with an upgrade.
When you associate the DVI port to an AV source in the BV6's configuration menus, see what other selection options you have: for example is DVD an option?
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
olvisab
- Posts 39
THanks elephant for your prompt answer.
I don't have the tv actually, I just intend to test it before buying it and I need to test the "dvi" socket with my pc.
Will it be possible to associate the dvi to the av button of my beo4?
Thanks in advance for your help
elephant
- Posts 2,215
Hi, I re-read your original post and I would like to clarify things.
Firstly, how B&O TVs have AV ports that you associate with the type of equipment attached. For example a SCART to a set top box or a VCR. This is accomplished by using the connections menu. So for example, you use the connections menu on the TV to indicate the DVI AV port is connected to a PC.
Secondly, for non-standard associations you need to add a soft-key (accessed via [LIST], [LIST] as you did) to the Beo4. It may be that your Beo4 does not yet have [PC] defined to its list of soft-keys. To add a new soft-key simultaneously press [LIST] and the stand-by button, the red/orange dot [O]. You should then see "ADD?" on your Beo4's display, press (GO), then press [LIST], [LIST] until you see "PC", then press (GO).
Finally, now you have [PC] defined so that when it is pressed the TV activates the AV port (in this case the DVI) associated with the [PC] command.
olvisab
- Posts 39
Hello Elephant
Thanks for these explanation.
I tried to add PC on the beo4 and I don't have this option ( cd2, cdv, camcord, doorcam, vtape, atape; p-v aux).
Can I associate camcord to the DVI port of the bv6 wth the connection menu and use this "camcord" button for selecting it ?
I hope it is simple like this.
I didn't know this way to modify a beo4.Great, thanks again.
Best regards
OLivier
olvisab
- Posts 39
When you say AV ports does this include the DVI port ?
If this is the case, according to what you say, I could use the doorcam or sat or v.aux ?
Best regards
Olivier
Raeuber
- Joined on 12-02-2007
- Posts 986
olvisab:
Best regards
Olivier
Yes, of course.
olvisab
- Posts 39
So, you solve my poblem.
Thanks for all these precision.
I am sure it will be helpfull for anyone who wants to modify their beo4.
Have a nice day
Best regards
oLivier
Callen
- Joined on 11-19-2008
- Posts 64
Raeuber:
olvisab:
Best regards
Olivier
Yes, of course.
Raeuber, I am not so sure this is the case on the BeoVision 6. On my BeoVision 5 (HD) it isn't a problem however the BeoVision 6 does not have the same options in the menu. I attach a photo of the setup choices on both the 6 and 5.
I may be doing something wrong but I'm fairly certain that on the BeoVision 6 the 'PC' mode is dedicated to the 'PC' button on the remote and cannot be reassigned.
olvisab
- Posts 39
A beovision 6-22 doesn't have HDMI port, only DVI.
It's incredible that this tv needs only one kind of remote, that's completely stupid.
I am afraid that you are right.
Thanks for this brain storming.
Olivier
olvisab
- Posts 39
Craig,
When you access to the main menu of the beovision, there is no way to select the DVI input by just selecting DVI in a list of input (like on any other TV) and press OK.And that's done.
I just need to switch to the dvi input.I don't care if I cannot use one button on a remote.
I just need to test the TV I intend to buy.
Please, let me know.
Callen
- Posts 64
With the software I have I'm afraid there is no way to select dvi (other than selecting pc on the remote).All other inputs can be assigned.
olvisab
- Posts 39
Software or not.That's a shame.
This is a really basic functionality.
Thanks again for your precious help :)
I intended to buy 2 of them, I give up.I don't want to spend my time finding the GOOD beo4.
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
I think you are being a little "unfair".
The Beo 4 is around since 1994!
How could they know that people will be using their TVs as PC Monitors???
Beovision 6-22 was introduced in 2003...
And buying the right beo 4 (ebay?) is not a big deal. Really.
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
olvisab
- Posts 39
Ralf,
Open a list of input and select a line with an arrow (up and down) with ok button, doesn't require any advance technology.Every manufacturer has done this since the "menu" function exist on a tv.
I use a beolink 1000 with my beosound 4 and I can select my sd card.
This is really stupid.
olvisab
- Posts 39
I called b&o and they told me that it could be programmed on my beo4 (just combination of button to add this option).
They recycle IR code, that's why I am able to use my A.MEM beosound 4 functionality with my old a.tape button from my beolink 1000.
Best regards
oLivier
Page 1 of 1 (18 items)
