Hi, I would like to hear from any one who has an Apple TV working with a BeoSystem 2. Mine is the older variety without a PC input option. I wondered if anyone else has got this arrangement to work? If you have, what configuration in terms of cables/connectors did you use and what did you need to tell the BeoSystem 2? Thanks for your advice and suggestions.
BTW. On my panel I have got a component input and I can convert the digital audio to plug into the BeoSystem 2.
