Latest post 01-28-2010 4:36 PM by Steve at Sounds Heavenly. 15 replies.
Page 1 of 1 (16 items)
  • 12-27-2009 7:20 PM
    Datalink Cables
    Hi, I recently purchased a Beosystem 5500 and was wondering if anyone could point me in the direction of some datalink cables for this setup.  I saw that Sounds Heavenly sells them, but $24 for 1m seems a bit pricey for me.  Could I use a 7-pin midi cable?  I'm located in the US, any help would be appreciated.
    Thanks,
    Chad
    Filed under: ,
  • 12-28-2009 3:10 AM In reply to
    Re: Datalink Cables
    I don't think you will find a better deal anywhere than Sounds Heavenly...
  • 12-28-2009 4:25 AM In reply to
    Re: Datalink Cables
    This sister site contains details on what is used by each cable ...
    BeoTech
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 12-28-2009 12:17 PM In reply to
    Re: Datalink Cables
    Cool, I haven't seen the Beotech section before.  So, would I be able to use a 7 pin midi cable?  Because I can get one for 9.99, and I think that's a better price than $8 a foot through Sounds Heavenly.  Then again, that particular cable is 25' and that's pretty ridiculously long.  I'm not knocking Sounds Heavenly or anything, I think they have a lot of good stuff, just that I wish I could find a cable for a little cheaper.  Thanks so much for your help guys.
  • 12-28-2009 12:24 PM In reply to
    Re: Datalink Cables
    Curious, what do you need the DLink for and how long? Don't the other devices have it included in this series?
    • B&o bottle opener
  • 12-28-2009 12:41 PM In reply to
    Re: Datalink Cables
    I need it to connect my Beogram CD5500 to the Beomaster, because when i bought the system, the cd player was missing its datalinkSad  As such, the length doesn't have to be very long at all.
  • 12-28-2009 12:43 PM In reply to
    Re: Datalink Cables
    tockvock:
    Hmmm... Let me have a look around, I may have one! BTW, I'm in the states... SC Smile
    ++++EDIT++++
    How does this look?
    • B&o bottle opener
  • 12-28-2009 3:15 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Datalink Cables
    I thought the CD5500 had a captive output cable. Is it in fact a CD50 you have? I know they came with outputs for either DIN or phono/RCA so the cables were completely detachable.
    You can use any fully wired 7 pin DIN cable for this, the problems only start with Beogram record decks which have to be shielded to ground to prevent humming.
    Chris.
  • 12-28-2009 4:07 PM In reply to
    Re: Datalink Cables
    Thanks for looking for me!  That does look about right.  Oh and in reply to Medogsfat, I do have the CD5500 and it doesn't have a captive output cable.  The Beocord and Beogram do, but the cd player does not.  Thanks!
  • 12-28-2009 4:14 PM In reply to
    Re: Datalink Cables
    You know what... that is exactly what I was thinking regarding the captive cable!?!? I am confused as I thought it had one too. Confused
    Is there indeed a DIN socket out? (There should be a "future use" digital out) Or, might the cable have been cut? Anyone?
    • B&o bottle opener
  • 12-28-2009 5:15 PM In reply to
    Re: Datalink Cables
    Thankfully the cable hasn't been cut, there's a din socket. Here's a pic of the back to clear up any confusion.
  • 12-28-2009 5:21 PM In reply to
    Re: Datalink Cables
    tockvock:
    Well, I'll be! There it is! Laughing
    I'll send you an email!
    • B&o bottle opener
  • 12-28-2009 5:25 PM In reply to
    Re: Datalink Cables
    Awesome, thanks!
  • 12-29-2009 9:59 AM In reply to
    • Medogsfat
    • Posts 4,045
    Re: Datalink Cables
    tockvock:
    Well we live & learnBig Smile
    Chris.
  • 12-29-2009 10:35 AM In reply to
    Re: Datalink Cables
    Very interesting! Clearly the US models catered for connection to other makes - though without a remote, the 5500 is pretty basic! Wonderful deck though - the early ones were probably the best CD players made by B&O - TDA1541A DAC and brushless motor.
  • 01-28-2010 4:36 PM In reply to
    Re: Datalink Cables
    Hi tockvock,
    Sorry I couldn't get you a better price in this case.  I'm not certain of the quality or suitability of the cable you linked to at musiciansfriend.com but I see they have included shipping costs within USA only, whereas I quoted you a price including free priority Worldwide shipping by Airmail.  Hence, this will be part of the reason for the price difference.
    I try to keep all of my prices competitive, but never at the risk of compromising quality or service.
    Kind regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
