Latest post 03-22-2010 4:42 AM by elistr. 6 replies.
Page 1 of 1 (7 items)
  • 07-02-2009 12:32 PM
    • bossbrad
    • Not Ranked
    • Joined on 07-02-2009
    • Colorado, USA
    • Posts 57
    • Gold Member
    BeoSound 9000 Issue
    I have a pre owned BeoSound 9000 (six disk) system that I have recently acquired.  The system was in storage for some time and had a good amount of dust on it. After cleaning it it work well for about a week. Now it seams to be having an issue playing cd's. This happens intermittently but the changer will get stuck on a disk and not move. If i try and press a cd it will stay at its current position and not grab the cd... then it will turn itself off. The strange part is if I try and hit cd then hit radio, the display will still say "CD 3" or whatever disk its trying to go to then turn off.
    Its very strange because it happens intermittently sometimes if I unplug the system for awhile then turn it back on its fine.
    Any suggestions? Is their away I could reset the system?
    Its a MKII if that helps at all.
  • 07-02-2009 1:03 PM In reply to
    Re: BeoSound 9000 Issue
    bossbrad:
    Quick: Recheck your dusting/cleaning and make sure that the (2) two small clear pyramidal bosses are SPOTLESS!
    • B&o bottle opener
  • 07-02-2009 4:08 PM In reply to
    • bossbrad
    • Not Ranked
    • Colorado, USA
    • Posts 57
    • Gold Member
    Okay I tried cleaning the bottom and top of the glass also the two pegs and still nothing.
  • 07-03-2009 1:26 PM In reply to
    bossbrad:
    OK
    On to Quick Step 2: Are the orientation screws on the back of the BS set correctly?
    • B&o bottle opener
  • 07-03-2009 10:34 PM In reply to
    • Kevin
    • Not Ranked
    • Joined on 03-02-2009
    • San Francisco
    • Posts 73
    It might be a failing CD mechanism and you'll have to take it to the shop.  Unsure
    BeoSound 9000, Beolab 8000, BeoLab 4000.   Beogram 4002/Grado Gold Amina conversion.
  • 07-16-2009 8:25 PM In reply to
    • bossbrad
    • Not Ranked
    • Colorado, USA
    • Posts 57
    • Gold Member
    UPDATE:
    I took it in to B&O and all it turned out to be was dirty. Apparently a bunch of gunk built up on the track and caused it to stick. After cleaning it and testing it for a few days it worked just fine.
  • 03-22-2010 4:42 AM In reply to
    • elistr
    • Not Ranked
    • Joined on 12-28-2008
    • Posts 3
    Hello
    I have question regarding my Beosound 9000:
    When playing CDs and tracks in random order, some time afterwards it paused (each time in another CD from the six).Can you advise me if there a malfunction in the beosound 9000? Or may be the optics of the CD mechanism has to be clean? If so, how can I clean it?Can I use cleaning CD?Or may be something else to be done? Please advise.
    Thanks Eli
