Latest post 05-16-2009 4:44 PM by Adrian Smith. 14 replies.
Page 1 of 1 (15 items)
  • 05-14-2009 12:24 PM
    ML/MCL Converter problem
    I have recently attached a ML/MCL Converter to my Beosound 3200, to power a pair of passive speakers, which were already integrated into my living room.  The converter is attached to the Beosound via a Masterlink cable, and the speakers plugged into the normal speaker sockets on the converter.  The Powerlink socket on the converter is currently empty, as is the IR socket.  The Beosound also drives a pair of Beolab 6000 speakers, via a separate Powerlink cable.
    The problem - no sound from the passive speakers.  The red light on the converter is on.  Do I need to configure/control the Beosound differently somehow?  Any ideas at all?
    Adrian
  • 05-14-2009 1:36 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: ML/MCL Converter problem
    Hi Adrian, and welcome to Beoworld. You need to connect the ML/MCL Converter to your Beosound via Powerlink. Also think you need a MK2 Powerlink cable. Sometimes called fully wired.
    CraigSmile
  • 05-14-2009 1:45 PM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Craig is correct - see also picture in attachment.
    There may be a "plop" in the speakers while switching on (no speaker delay)
  • 05-14-2009 3:00 PM In reply to
    Sorry, forgot to mention that I tried it with powerlink as well, to no avail (not fully wired however).
    Your answers give rise to a couple of questions:
    1, what's the masterlink socket for?
    2,where did you get the attachment picture from?
    Adrian
  • 05-14-2009 3:46 PM In reply to
    • Craig
    • Posts 4,855
    Adrain, the Masterlink socket has two purposes. Firstly if it is been used as a Beolink Passive. In connection with the remote eye. Secondly if you had an existing MCL based multiroom setup. Then decided to replace your Audio Master with a Masterlink one. You would connect to the converter to Audio Master via Masterlink. Then the MCL connection would go it the speaker connections of the converter. As for the diagram we have user and service manuals available to download. You will need to be either a Silver or Gold member to be able to do this.
    CraigSmile
  • 05-14-2009 3:47 PM In reply to
    • Mico
    • Top 500 Contributor
    • Joined on 05-06-2007
    • Finland
    • Posts 136
    1. Masterlink is used for converting the ML signalling from a ML based system (like BS3200) to an existing MCL-setup. It powers the passive speakers in the link rooms in a MCL network.
  • 05-14-2009 3:49 PM In reply to
    • symmes
    • Top 200 Contributor
    • Joined on 04-21-2007
    • Freedonia
    • Posts 290
    Assuming you are not connecting to an existing MCL network, you need fully mounted powerlink and a link eye to trigger the amplifier.
  • 05-14-2009 3:55 PM In reply to
    • Gerd
    • Germany
    • Posts 523
    Adrian Smith:
    Adobe Photoshop Big Smile
  • 05-15-2009 5:56 AM In reply to
    symmes:
    You either use Mk2 fully wired powerlink OR Masterlink and a link eye.
    Regards Graham
  • 05-15-2009 8:58 AM In reply to
    • symmes
    • Freedonia
    • Posts 290
    Duh.  My apologies.  Complete brain cramp, or lack thereof.
    r
  • 05-16-2009 12:41 PM In reply to
    Success!!
    Thanks for your help, a fully-wired powerlink did the trick - without an eye.
    Now, how do I adjust the volume balance between the existing active speakers, and the new passive ones?
    Adrian
  • 05-16-2009 1:09 PM In reply to
    • Gerd
    • Germany
    • Posts 523
    You can't
  • 05-16-2009 1:59 PM In reply to
    That's a pity, but I did expect it.
  • 05-16-2009 2:24 PM In reply to
    Adrian Smith:
    Success!!
    Adrian
    You can only do this with Masterlink and the Remote Eye. You have just discovered the difference between the two wiring conventions.
    Regards Graham
  • 05-16-2009 4:44 PM In reply to
    Perhaps a future modification is in order.  Thanks for the info.
    Adrian
