1st March February 2012
Latest post 07-01-2011 12:59 AM by Paul. 31 replies.
02-14-2009 7:52 AM
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Then, we can see what we can do with the fabric. It is glued around the perimeter of the front baffle, under the straps, and on the "Bang & Olufsen" script so that it shows through. Apart from the glue, there should be nothing left that could be damaged by water (don't do this with the smaller models that have, I believe, a chipboard front!).
Luckily, the glue doesn't seem to mind water at all so we can splash all we want. I first tried lukewarm water, but the stains didn't come off, so I decided to try my luck with mild dishwashing liquid. It worked better, helped with a soft brush.
What makes this difficult is that at least this black cloth will look very clean as long as it remains wet, so you don't know right away whether you were successful. Also, rinse well so that the last puddle of dirty water won't leave a stain once it's evaporated.
I managed to resist the temptation to use a hair dryer in case the moisture and heat together would finally dissolve the glue. Here's the dirtier front cover while still wet.
tournedos
- Finland
- Posts 5,808
Let the front covers dry properly - moisture trapped inside the speaker can't be a good thing - and then inspect the results.
Mine are still a tad damp, so I'll return with the assembly process and final results after I've run some errands meanwhile.
Back from shopping, it's been almost four hours since I first started, and motivation is slightly diminishing. Some adjustment oil is therefore necessary.
tournedos
- Finland
- Posts 5,808
The covers are now dry, so it's back to everyone's favourite from all service manuals: "assembly is the reverse of dissassembly."
Install the "Red Line" frame, and then position the drivers and the crossover back where they were. Install all brackets and replug the wires. If any of the connectors have become loose, pinch them a little with pliers before reinserting. A high-endist would replace the wires and solder them on without connectors, but I can't be bothered. Also, squeeze the wires back between the plastic pin holders so they won't have a chance of rattling about at high volume.
Here's one I prepared earlier (don't you love that one as well?):
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Thank Mika, great thread. Looks like all Redlines are pretty much the same inside.
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
tournedos
- Finland
- Posts 5,808
Good luck, it is quite rewarding! I actually recapped a pair of 60.2s as well this winter, but that thread is pretty much useless since the pictures didn't survive the forum upgrade.
Anyway, the thing I learned was not to trust the service manual, the crossovers in mine were quite different in the tweeter network. So open them up first and check the values before ordering new caps.
The end result was well worth it. They sound so different that it actually took a while just to get accustomed to the change.
ouverture
- Joined on 04-20-2007
- London
- Posts 282
good to know, I am sure that if you sent the pictures to Keith or Lee again, they could re-instate them for us
rayfenwick
- Joined on 04-28-2007
- Hull UK (again)
- Posts 693
tournedos:
<snip>
I hope the readership finds this useful or at least entertaining.
I found it both! In my opinion these write-ups are one of the essential ingredients of BeoWorld, and I hope that posts like yours will encourage more people to create more - Great work.
Ray
Я люблю Банг и Oлуфсен
rayfenwick
- Hull UK (again)
- Posts 693
Eugene1960:
Recapping both set of my Redlines the 60.2 and the 60's made all the difference in the world. Wasnt really all that difficult. But Mika is correct in stating check your board. The cross on his set looks nothing like the cross on mine. As I recall my caps were 22uf 15 uf and two 6.8 uf for the 60.2 and 15, 10, 6.8 and 4.8 uf for the 60's. and then there are the resistor values which can be different.
I went ahead a reclothed mine while I was at it.
That's an excellent idea - for some reason I'd not thought about "colour changing" RL's.. is there any chance of more/bigger pics?
Ray
tournedos
- Finland
- Posts 5,808
ouverture:
Actually they are not that relevant - mine were apparently a very early pair, and the crossovers were constructed on chipboard. You're more likely to have real printed circuit boards, and the job will be much easier.
Anyway, here's the schematic from another thread - the left version is from the service manual, the right is what I had in my 60.2's. The bass & mid networks were identical with the manual version.
rayfenwick
- Hull UK (again)
- Posts 693
tournedos:
I like those, Eugene! Would look great in a suitable environment.
I agree. Very nice indeed. Thanks for the pics!
Ray
