Latest post 01-12-2009 7:56 AM by Chieljan. 2 replies.
Page 1 of 1 (3 items)
  • 01-12-2009 6:25 AM
    Beomaster 1200 coupling capacitors
    Hi all,
    The 2 big coupling caps in my beomaster 1200 have gone leaky. They still seem to work but I'd like to replace them, since black smear coming out of them can't be a good sign.
    The schematic calls foor 3000uF caps, would 3300uF caps work fine too?  Those are the only type my local electronics supplier sells...
     Seems to me well within the tolerance, but I'd like to be sure :)
     Thanks in advance!
  • 01-12-2009 6:54 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 1200 coupling capacitors
    I agree, they should be replaced.
    3300uF will work fine and actually improve the output stage's bass response and damping factor a bit. Remember to polarize them correctly.
  • 01-12-2009 7:56 AM In reply to
    Awesome, thanks martin!
    I'm going to get soldering.
    Laughing
