Latest post 11-24-2008 11:36 AM by Dillen. 8 replies.
Page 1 of 1 (9 items)
  • 11-22-2008 4:30 PM
    • Chasp
    • Not Ranked
    • Joined on 10-22-2008
    • Posts 10
    Beovox 1000 Grill Removal
    I want to remove the grills from one of my Beovox 1000's to check a speakers. I am new to the vintage scene and do not want to damage the fabric, by just going at the grills.
     Does anyone have any tips for a newbie?
    Also, if I should find that I need a new cone or something am I out of luck or can something be used in place of OEM?
    Chas.
  • 11-22-2008 4:42 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beovox 1000 Grill Removal
    Chas, the grills will come off if you lever them with a large flatblade screwdriver.
    CraigSmile
  • 11-23-2008 10:37 AM In reply to
    • Chasp
    • Not Ranked
    • Posts 10
    Craig,
     Thanks for the info.
  • 11-24-2008 2:46 AM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    The grills are mounted using small countersunk nails.
    I would recommend a wide spatula to avoid damaging the edges of the wooden cabinet.
    You can sink the nails again when mounting by using another nail between the hammer and the nail to be mounted, drive it in to head apprx 1mm under the cloth.
  • 11-24-2008 6:00 AM In reply to
    Another 'tip' could be: why fix it if it ain't broke ?' :):)...
    They're from the 'paper/wood/metal' era so you don't have to be afraid of foam-rot :)
  • 11-24-2008 9:08 AM In reply to
    • Chasp
    • Not Ranked
    • Posts 10
    I did take the grill off and found that the woofer has a hole. Now the question is how to replace the woofer.
     This is all new to me so any help is greatly appreciated.
  • 11-24-2008 9:19 AM In reply to
    • Dillen
    • Posts 5,008
    A hole ? How about the front grill, is it damaged too ?
    How big is the hole and where is it ?
    Depending on the size and location, it may be fixed by straightening any remains of the frayed cone and glueing a piece of coffee filter paper onto the cone using speaker cement or, in this case where the cone is merely cardboard, plain white paper glue.
    If it's a large hole, the only method could be replacing the woofer. I am sure that I have a good used woofer in stock if you need and probably also a nice front grill.
    The woofer has four screws and then careful lever it up using a couple of wide screwdrivers or similar. The drivers can bind drastically.
  • 11-24-2008 10:27 AM In reply to
    • Chasp
    • Not Ranked
    • Posts 10
    Martin,
    It is a small hole near the outter edge of the paper cone and the black rubber glue ring, if that is the correct term, the paper is still present and fits nicely into the space it once occupied.
  • 11-24-2008 11:36 AM In reply to
    • Dillen
    • Posts 5,008
    Fine, then fix it with a bit of contact glue (Evostick in the UK), that will also keep it slightly flexible.
