I'm at wits end. My mac-mini started screwing up in an odd way (dock wasn't showing, couldn't do a restart) that appeared permission related so I tried to repair permissions. The error I receive is something like Disk Utitlity has "Lost Connection" with Disk Management tool" Please quit Disk Utility. When I look in at the log file, all I see is a "buffer overflow!" message. Nothing else.
Research found a very similar problem associated with iTunes 6 on Mac OSX 10.3, but I'm running iTunes 7.1.1 on OSX 10.4 (and I tried the fix anyway and it did not work).
Deeper research found similar problems associated with a screwed up file or application, but the offending application/file would be displayed in the log file. The "buffer overflow" I'm getting seems to happen right away.
The disk verifies fine.
Ok, I give up, I'll just restore the system from my backup... except the backup from 4 or 5 months ago has the SAME problem!!!
I don't want to rebuild the system from scratch because I had a lot of problem doing this the last time... although, I suppose, given the trouble I had doing the rebuild it's quite possible that this problem has always been there. I did a complete rebuild about 6 mos ago when my upgrade to 10.4 failed midway (I was upgrading to run eyeTV). I don't run "repair permissions" habitually so it's possible I never caught this.
Any suggestions aside from starting over.[:'(]
Thanks in advance,
Stan
