Latest post 08-11-2007 4:24 AM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 08-11-2007 12:12 AM
    BEOCENTER 9500 Speaker Options
    Hi guys...
    Quick question here. What are the options on the Beocenter 9500 for choosing speakers. ie. Is Powerlink 1 and Speaker 1 (for passive) connected and chosen as one option....thus Powerlink 2 and Speaker 2 the same????
     Or can all 4 be separated??
    Thanks,
    k
  • 08-11-2007 4:24 AM In reply to
    Re: BEOCENTER 9500 Speaker Options
    They are separate. Remember that Powerlink actually contains both right and left channels in each outlet. What many people do is use Powerlink in the main room and MCL from Speaker 2 in the rest of the house. You can run both active and passive from MCL using the right connection boxes. Mute will mute both Powerlink sockets so it is not really designed for independent use in two rooms. That is what the MCL is for.
