Rombeek: Peter,
Do you know the Pioneer type?
Marcel
I´ve read in a Swedish magazine "Hifi&Musik" for a while ago that the BC2 and BV 7 using the drive unit from Pioneer DV-989 but not all of its fine components sadly. They using the same video DAC:s (14bit 108Mhz) and audio DAC:s (Burr-Brown) as the Pioneer, but not the same output stage and signal filters and more, and more.
B&O have made a compromise as usually because the small size and the advanced design. They have only put in the most important components from the Pioneer and skipped all the audiophile and video upscale processor chips/components, and replaced them whit smaller more poorly ones.. Example in sound: The Pioneer have 118db Signal/Noise ratio and the BS2 have only 105 S/N. BV7-40
And the result from one of the best DVD players on the market (Pioneer DV-989 AVI-s) transformed to a half good DVD-player by B&O ( the Beocenter 2 and the BV 7-).
Regards Fredrik L
