1st March February 2012
Latest post 07-03-2008 6:55 PM by Beolab. 85 replies.
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
Re: My BV 7-40 MKIII Full HD Dark Grey has finally arrived! Pictures, info, and much more...!
Razlaw:Is it really that difficult? The tv weighs 99 pounds? Correct? Is that with or without the stand?
I think the quoted weight excludes the stand. Put it this way, I barely could lift the floor stand. It's got to be heavy, to accomodate the weight of the TV.
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
So it is question of being awkward as for the BV7 as opposed to weight? A 50 inch BV4 is 112 pounds according t B and web site whereas the BV7 is only 99 punds.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Razlaw
- Illinois
- Posts 1,770
Have now talked to the dealer and been given the combined size of the 2 pallets/boxes for the stand and BV7, we are having it shipped/delivered.
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
patience is a virtue ;) Especially when you spend 20 grand on a tv!
Razlaw
- Illinois
- Posts 1,770
Dealer is installing our new BV 7 July 2nd. Patience and caution won out over our eagerness to get it quickly.
Razlaw
- Illinois
- Posts 1,770
Beolab: I have discovered in the service menu that this panel are a (Samsung) and called LTA400HS-LH2. (High Glare panel)
How do you find the service menu you refer to?
Beolab
- Joined on 05-18-2007
- Sweden
- Posts 535
Razlaw: Beolab: I have discovered in the service menu that this panel are a (Samsung) and called LTA400HS-LH2. (High Glare panel)
Do not change anything in this menu. The combination to the costumer menu is: Menu, then set the marker at Options and hit red button + Go. Under screen information you can see the panel type (Your panel is LTA400HT-L04) , and under signal information you can see the the input resolution and output res and frequency. What are your first impressions of your new BV7 Dark Grey so far? Have it lived up to your expectations, and have you tried out Blue-ray 24p on your set? Regards
Razlaw
- Illinois
- Posts 1,770
The picture is stunning with both BluRay and high def. I am not sure if the 24p s working. Dealer had software problems when installing it, spent 4 hours. They said it was installed howvere when speaking on the phone with the salesman he is not sure as the BluRay is not getting the right commands on the menu, no fast forward or chapter skipping. Is there a way to check to see if 4.24 is installed? TV was to be gray but was delivered as silver, it appears box was mismarked at 'B and O so dealer is ordering us a new one. Regarding the customer menu, once I view it, how do I get out of it to avoid changing anything, just hit exit?
Russ
- Joined on 05-07-2007
- Washington, DC USA
- Posts 641
In the service menu there is a SW information selection which you can look at. Yes, just press 'exit' or 'menu' to get out. Russ
We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA USA
Razlaw
- Illinois
- Posts 1,770
Beolab: Razlaw: Beolab: I have discovered in the service menu that this panel are a (Samsung) and called LTA400HS-LH2. (High Glare panel)
Thanks....my panel is the LTA400HS-LH2
Beolab
- Sweden
- Posts 535
Razlaw: Beolab: Razlaw: Beolab: I have discovered in the service menu that this panel are a (Samsung) and called LTA400HS-LH2. (High Glare panel)
Funny thing that B&o use two different panels in the BV7 MK3... (The HT and the HS)...
