Latest post 02-27-2008 7:43 PM by Peter Pan. 28 replies.
Page 2 of 2 (29 items) < Previous 1 2
  • 02-27-2008 5:14 PM In reply to
    Re: Can I use a Non B&O Sub with a Beosound3000 and Beolab6000's.
    PowerLink MK III. Cable connection.
  • 02-27-2008 5:19 PM In reply to
  • 02-27-2008 5:58 PM In reply to
    1st, I know the signal-out leads from the pins of PL and DIN-AUX are mirrored or in an opposite way.
    2nd, the drawing I was refering to, the one Beobird posted and made by you, says the PL-out goes to the sub. (Which is the right thing to do)
    What is confusing me is that you say it has to be connected through AUX, which is not right. Because:
    3rd, the A.AUX (not the PL) of a BS9000 is a fixed signal. Volume of the BS9000 is not relevant. If you connect these leads to any sub, the volume is not controllable, thus very loud in this case.
    To resume, the A.AUX cannot be used. The sub has to be controlled through PL.
  • 02-27-2008 7:43 PM In reply to
    Yes, and the right way to connection a sub to day 2008, also to Beolab 2 er.
    Wiring diagrams. Forbindelse af Subwoofer til B&O's Power link. Eks:
    Peter Pan.
