Latest post 10-07-2007 11:07 AM by prototek. 26 replies.
Page 2 of 2 (27 items) < Previous 1 2
  • 10-07-2007 6:33 AM In reply to
    Re: Keep My 4500 or Get the 9000? Opinions Please.
    On that note, I attach a photo of the capacitors removed from my M100s!
  • 10-07-2007 11:07 AM In reply to
    Peter:
    Not bad if mounted properly. I would suggest changing the capacitors in the cross over if they sound dull - works wonders.
    I'm quite handy with a soldering iron. Which caps would you suggest as a replacement?
