Latest post 07-18-2007 2:57 PM by Gerd. 29 replies.
Page 2 of 2 (30 items) < Previous 1 2
  • 07-18-2007 12:18 PM In reply to
    Re: Beovision 7 1080p
    Well spotted! BL7.3!Big Smile
  • 07-18-2007 12:40 PM In reply to
    • Munin
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Posts 99
    "There is the option of a DVB-S/T"
    Does this mean "There are good chances that it will be fitted with a DVB-S/T"?
    Just curious
    /Munin
  • 07-18-2007 1:26 PM In reply to
    It is an option, as it is on the BS3. You really should join as a silver member and get the manual - there are a number of surprises in it!! Smile
  • 07-18-2007 1:45 PM In reply to
    • Doc
    • Top 150 Contributor
    • Posts 585
    On page 62, down at the left, it says DTS-ES and NEO 6. Was the MK2 also able to play this?
  • 07-18-2007 2:57 PM In reply to
    • Gerd
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    No - AFAIK Dolby digital 5.1 (AC3), Dolby prologic and DTS 5.1 only
