Latest post 02-29-2012 11:16 AM by Razlaw. 32 replies.
Page 2 of 2 (33 items) < Previous 1 2
  • 02-28-2012 1:37 PM In reply to
    Re: Rear speakers with Beolab 5s
    Thanks! That makes it much easier and more doable.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 02-28-2012 1:38 PM In reply to
    • valve1
    • Top 500 Contributor
    • Joined on 05-27-2009
    • Dublin Ireland
    • Posts 213
    • Gold Member
    Razlaw:
    a solid speaker base of granite, or even wood is going to get to be extremely heavy. If the base is not solid, I am afraid it might affect the sound quality?
    What are your floors, suspended or solid with covering ?
    I am guessing you would need to raise your 9's about 8inches give or take depending on your "slouch  height".
  • 02-28-2012 1:54 PM In reply to
    They are wood floors, with carpet, over a basement. I am thinking you are corect about the 8 inches. Mid and bass will still be below the top of the furniture. Could raise them more to get mid up above but then the tweeter might be a bit high.
  • 02-28-2012 2:25 PM In reply to
    • valve1
    • Dublin Ireland
    • Posts 213
    • Gold Member
    8 inches  of any sort of stone is going to be heavy, but the same in solid wood might be an option....? It need not be oak but if its natural wood make sure its kiln dried to what ever works in your neighbourhood. High density plywood stacked in layers is another option.
  • 02-28-2012 3:38 PM In reply to
    Does the type of wood make a difference? Kiln dried?
  • 02-29-2012 2:49 AM In reply to
    • valve1
    • Dublin Ireland
    • Posts 213
    • Gold Member
    Razlaw, I did answer this but I must not have pressed post or its going to show up later. If its a no show i will repost to morrow.
  • 02-29-2012 8:52 AM In reply to
    In my opinion the height of the 9's is really the problem as even with a very low seating position the speakers emit the sound towards the back of your sofa....
    Constructing something like a stand seems like a tough job to me as the 9's have the bass in their base and you need to construct something very solid to avoid the low frequencies being emitted to the stand....
    I would go 5's in the front, 3's in the back... optical fit and you have enough bass from the 5's
    Best regards
    Stephan
  • 02-29-2012 11:16 AM In reply to
    I am going to do some experimenting with the 9s I have now and see what I think of the sound. I am very intrigued by having matching speakers all around.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
