        1st March February 2012
	    Latest post 04-23-2011 8:32 AM by Medogsfat . 61 replies.
								    |  04-12-2011 4:23 AM |  |
									                 DillenJoined on 02-14-2007Copenhagen / DenmarkPosts 5,008 |
										    Going through my pile of round-to-it machines, I discovered this little beauty.It's a JET 606.
 Of the many classic late 50's tabletop sets, this is, in my opinion, one of the most beautiful models and
 a set like this should be used and enjoyed, not just sit around in a large carton in a storage facility as
 it has been doing for the last 15-20 years.
 Martin |  |
										    A beautiful model and a wonderful chassis to work on.I recently restored a JET 606 Moderne, which is exactly the same chassis, only in a more stylish
 and modern, more boxy cabinet.
 Unfortunately, that one didn't make it to the new owner in one piece but that's a completely different story. Martin |  |
										    Looking at the JET 606, it seems to be nice and intact.The dial lettering shows a little blurring. Unfortunately, this is quite common for some models but in this
 case it is not very drastic.
 Martin |  |
									                 EugeneJoined on 12-17-2008Posts 589 |
										    Very nice Martin.  I have a couple old radio sets myself I am planning on reworking this summeer. Not B&O but USA brands from back in the days when we actually made stuff like that. |  |
										    Yes, I think it will be another resto-thread.It has been some time since my previous one and this set seems to be a good candidate.
 The cabinet is largely undamaged, it has the tiny ding and the odd scuff here and there, nothing drastic here either.The rear and underside covers are in place and looking their best.
 Martin |  |
										    All knobs are present, and most of them seems to operate nicely.Actually only the dial knob does nothing. It won't rotate, but just sits there like it was glued to the chassis.
 This will have to be investigated. My guess is that the dial string has snapped and is now blocking
 the mech somehow. Still, I would imagine that a fault like that would still allow for a little movement
 of the knob, if nothing more than just a spring tension feel. I will have to look into it when I get the covers off.
 And exactly that will be the next thing.
 Off with the back and let's have a look inside.
 All valves are present and in their correct positions, it seems.
 Dust in a nice layer.
 A little amount of spiderweb.
 A little surface oxidation to the aluminum cans.
 Nothing uncommon and nothing alarming.
 Martin |  |
										    The JET 606 was made for the 1960 season and was featured in the 1959/60 catalogues, actuallythe Moderne version took pride of place on the page.
 Martin |  |
										    The model name JET suggests a position right in the middle of the model range, functionality-wise.Jet was a bigger and better build than a MINI but cheaper and not quite as
 technically advanced as a GRAND PRIX.
 Martin |  |
										    The JET 606 is a fairly large set that typically saw use as the daily set in the livingroom of a middle-class home.It has provisions for connecting a record player and an external speaker.
 Being a Bang & Olufsen set of this nature, it will be a good performer and thanks to
 the PL84 output valve, it will provide a whopping 4,5 Watts output power.
 That was quite an amount at the time and no doubt it will easily be able to fill a normal livingroom with sound,
 especially if an additional external speaker is connected.
 Other features are the built-in FM antenna and an also built-in and even rotatable AM antenna.
   Martin |  |
										    tone control, a magic eye and a two-way speaker system
 Martin |  |
										    The plug-in module that sits right in front of the output stage with its ECC83 preamplifier valve workswith the record player input and functions as an adapter for different types of pickup cartridges.
 The one currently fitted is for a Crystal type (high ohmic) cartridge.
 Glued to the inside of the cabinet is an envelope that originally held the schematics.
 Martin |  |
										    Hey, the sheet with the schematics is still in there !I will leave it there. I will work from the service manual anyways and the schematics may
 come in handy in 50 years when the next repairer will be servicing it.
 Martin |  |
										    Actually, that schematic is practically all you need if you have a little basic experience with servicingvalve sets. I am particularly fond of the valve pinout drawings at the bottom of the page.
 Expected voltage readings are printed here for selected valve pins which allows for a fairly quick
 diagnose of the most common faults. Very nice.
 You won't find anything like it in any modern set.
 Martin |  |
										    Bottom cover
 Martin |  |
										    Off with it   Martin |  |
										    More spiderwebs
 Martin |  |
										    But nothing the vacuum cleaner can't handle.There, much better.
 Now I can see the components.
 Martin |  |
										    Actually, I can now also see why the tuning knob has seized.The dial string looks fine but the knob spindle that also bears the large flywheel has an amount
 of surface rust, just enough to have rusted solid in its bearings.
 The bearings are square pieces of fiberboard with holes.
 A single drop of oil in each bearing and a little exercise saw
 the tuning pointer travelling nicely again when the knob is rotated.
 One fault cured.
 Martin |  |
										    Well, back to taking out the chassis.It's held in place by two screws.
 One came out right away, the other one had about half an hours work worth of rust.
 I had to oil the threading a bit to losen it but out it came.
 The two speaker leads had to be cut and the chassis will now slide out.
 Martin |  |
										    It comes out in one piece, bringing with it the dial and all knobs.Wonderfully easy to work with now.
 Martin |  |
										    A typical build from B&O at that time. Using both the old fashion birds nest structure andprinted circuitboards.
 In this set, the FM frontend is housed in a shielding metal casing and is built on a circuit board,
 the amplifier is on another board and the rest is a birds nest construction.
 Martin |  |
										    The chassis is on the bench now.Visual fault finding in progress.
 There are no very nasty surprises but still a couple of issues stand out:
 The fuse and its holder has oxidized to a point where replacement is the only way.
 It seems to be almost a rule in these old sets and luckily it's an easy fix with two new clamps and
 a new fuse.
 Before
 After
 Martin |  |
										    There are more things that need to be checked before applying power.The suppression capacitor is normally one of them but this set does not have
 a suppression capacitor but instead a kind of decoupling capacitor that sits across the rectifier.
 That is the blue capacitor to the left.
 This little sorry looking thing was placed right next to a couple of warm ceramic power resistors. No wonder
 it grew tired. It's a 5Kv component and in its current state nothing I would like to put across anything mains
 with me nearby.
 A brand new MKP type foil capacitor replaced it.A couple of pieces of heat-resistent silicone wire insulation was mounted to its pins for added protection.
 Martin |  |
