The Big thing currently missing in all of B&O's TV's, considering they can be used as a processor for AV duties via an inbuilt module, is compatibility with the latest Dolby and DTS Home Theatre codecs - i.e. Dolby True HD and DTS HD Master Audio.
Considering the audible and beneficial increase in audio performance of these lossless compression formats, and that they are a standard in the industry, along with Bluray for Home Movies which is both designed to be, and is in fact fast superseding DVD as the premier AV software for movies, it is lamentable that B&O have not seen fit to update their AV sound modules from the earlier and inferior DD or DTS lossy compression formats.
Certainly given the expense of any B&O TV, and where one would like to gain the advantages of simplification re the box count by having DD & DTS decoding built into the set, it is a serious oversight in my view - certainly one that makes me hesitate to buy a B&O TV unfortunately - much as I want to buy one on aesthetic and performance grounds.
If you are listening B&O, this is one of the areas where you need to address product shortcomings in my humble opinion.
Best Regards
John.....
No-one ever regretted buying quality.
